Kennt sich hier jemand mitm LEON3 aus?
Verfasst: Sa 14. Jun 2014, 18:12
von Easyrider
Ich hab hier nen LEON3 für nen Digilent Spartan 3 Board konfiguriert.
Kann den auch reinladen, nur an welcher Stelle sag ich dem memorycontroller wieviel Ram draußen dranne ist und ab welcher adresse der startet?
mein info sys sieht folgendermaßen aus:
[sys]      SESSION: Thu Jun 12 15:08:21 2014
[sys]      GRMON version: v2.0.48 eval version
[sys]      OS: Windows
[sys]      Command line: grmon.exe -digilent -u -log term.out
[sys]
[sys]      GRMON2 LEON debug monitor v2.0.48 eval version
[sys]
[sys]      Copyright (C) 2013 Aeroflex Gaisler - All rights reserved.
[sys]      For latest updates, go to http://www.gaisler.com/
[sys]      Comments or bug-reports to support@gaisler.com
[sys]
[sys]      This eval version will expire on 27/08/2014
[sys]
[sys]       JTAG chain (2): xcf04s xc3s1000
[usr1]     GRLIB build version: 4113
[usr1]     Detected frequency:  40 MHz
[usr1]
[usr1]     Component                            Vendor
[usr1]     LEON3 SPARC V8 Processor             Aeroflex Gaisler
[usr1]     JTAG Debug Link                      Aeroflex Gaisler
[usr1]     LEON2 Memory Controller              European Space Agency
[usr1]     AHB/APB Bridge                       Aeroflex Gaisler
[usr1]     LEON3 Debug Support Unit             Aeroflex Gaisler
[usr1]     Generic AHB ROM                      Aeroflex Gaisler
[usr1]     Single-port AHB SRAM module          Aeroflex Gaisler
[usr1]     Generic UART                         Aeroflex Gaisler
[usr1]     Multi-processor Interrupt Ctrl.      Aeroflex Gaisler
[usr1]     Modular Timer Unit                   Aeroflex Gaisler
[usr1]     PS2 interface                        Aeroflex Gaisler
[usr1]     VGA controller                       Aeroflex Gaisler
[usr1]     General Purpose I/O port             Aeroflex Gaisler
[usr1]
[usr1]     Use command 'info sys' to print a detailed report of attached
cores
[usr1]
[usr1]     grmon2> info sys
[usr1]     cpu0      Aeroflex Gaisler  LEON3 SPARC V8 Processor
[usr1]               AHB Master 0
[usr1]     ahbjtag0  Aeroflex Gaisler  JTAG Debug Link
[usr1]               AHB Master 1
[usr1]     mctrl0    European Space Agency  LEON2 Memory Controller
[usr1]               AHB: 40000000 - 80000000
[usr1]               APB: 80000000 - 80000100
[usr1]     apbmst0   Aeroflex Gaisler  AHB/APB Bridge
[usr1]               AHB: 80000000 - 80100000
[usr1]     dsu0      Aeroflex Gaisler  LEON3 Debug Support Unit
[usr1]               AHB: 90000000 - A0000000
[usr1]               AHB trace: 256 lines, 32-bit bus
[usr1]               CPU0:  win 8, hwbp 2, itrace 256, V8 mul/div, lddel
1
[usr1]                      stack pointer 0xa0000ff0
[usr1]                      icache 2 * 2 kB, 32 B/line lru
[usr1]                      dcache 2 * 2 kB, 32 B/line lru
[usr1]               ilram 1 kB, 8e000000 - 8e000400
[usr1]               dlram 1 kB, 8f000000 - 8f000400
[usr1]     adev5     Aeroflex Gaisler  Generic AHB ROM
[usr1]               AHB: 00000000 - 00100000
[usr1]     ahbram0   Aeroflex Gaisler  Single-port AHB SRAM module
[usr1]               AHB: A0000000 - A0100000
[usr1]               32-bit static ram: 4 kB @ 0xa0000000
[usr1]     uart0     Aeroflex Gaisler  Generic UART
[usr1]               APB: 80000100 - 80000200
[usr1]               IRQ: 2
[usr1]               Baudrate 38461
[usr1]     irqmp0    Aeroflex Gaisler  Multi-processor Interrupt Ctrl.
[usr1]               APB: 80000200 - 80000300
[usr1]     gptimer0  Aeroflex Gaisler  Modular Timer Unit
[usr1]               APB: 80000300 - 80000400
[usr1]               IRQ: 8
[usr1]               8-bit scalar, 2 * 32-bit timers, divisor 40
[usr1]     ps2ifc0   Aeroflex Gaisler  PS2 interface
[usr1]               APB: 80000500 - 80000600
[usr1]               IRQ: 5
[usr1]     adev11    Aeroflex Gaisler  VGA controller
[usr1]               APB: 80000600 - 80000700
[usr1]     gpio0     Aeroflex Gaisler  General Purpose I/O port
[usr1]               APB: 80000800 - 80000900
[usr1]
[usr1]     grmon2> exit
[usr1]
Wenn ich die Konfuguration eines ehemaligen Mitarbeiters reinlade kommt zum mctrl0 noch folgende Zeile dazu:
32-bit static ram: 1 * 1024 kbyte @ 0x40000000
Nochmal: wo muss ich das einstellen? Ich finde in der xconfig einfach nix. Ich kann nur den Memory-controller enablen, der dann ja auch drin ist, aber an welcher stelle bekommt das ding gesacht dass da ein MiB drannehängt?
