ATtiny1616 internen TEMP Sensor auslesen (Arduino)
Farbe
Beitrag von Farbe »
Hallo Leute,
ich hab ein problem mit meinem ATtiny.
Ich will eigentlich nur abwechselnd eine Spannung (Batterie status) und die Temperatur messen.
Leider klappt das nicht so recht, irgendwie kommen immer 600k raus -> 326°C ... kann irgendwie nicht sein.
Benutzen tu ich den megaTinyCore.
Code:
Setup
// ADC values
unsigned long lastMeasurement = 0;      	    // time ADC mesurement was last taken
int measurementTime = 100;                	    //interval for taking measurements
bool batt = true;                                   	   //wich measurement to take next batt/temp
bool measurement = false;                  	     // measurement in progress
// battery voltage
int battery = 128;							// initial value
// temperature related values
unsigned long temp = 0;						//initial value
int8_t sigrow_offset = SIGROW.TEMPSENSE1; 	    // Read signed value from signature row (calibration)
uint8_t sigrow_gain = SIGROW.TEMPSENSE0;   	   // Read unsigned value from signature row (calibration)
///////////////ADC einstellen///////////////
ADC0.CTRLB = 0b00000001;                              	   //2 sampels accumulation
ADC0.CTRLC |= 0b01000111;                  	           //reduced sampling c, internal vref, /256 clk divider
ADC0.CTRLD = 0b10110001;                      	          //inital sample delay 256, sample delay variation on,
ADC0.SAMPCTRL = 0b00001111;                	          //sample lenght = 7
ADC0.CTRLA = 0b00000101;                     	           //ADC on, 8bit, single conversion
Loop:
if(ADC0.COMMAND == 0b00000000 && measurement == true){           	   // measurement done, process value
        if(batt == true){                	     // if this is a battery mesurement process it inside checkBattery
          checkBattery();
        }else{
          checkTemp();                   	     // otherwise process inside checkTemp
      if((millis() - lastMeasurement) >= measurementTime){          	  // check for time up to make a new measurement
      lastMeasurement = millis();                                 	    // save last time mesurement was taken
      if(batt == true){
      analogReference(VDD);                                                	     // vref to 5V (VDD) for battery measurment
      ADC0.CTRLA = 0b00000100;                                            	      //ADC off, 8bit, normaler modus
      ADC0.MUXPOS = 0b00000111;                                              	   // AIN7 as input (connected to vBatt)
      ADC0.CTRLA = 0b00000101;                                                	  //ADC on, 8bit, normaler modus
      ADC0.COMMAND = 0b00000001;                                        	        //start conversion!
      measurement = true;
      }else{
      analogReference(INTERNAL1V1);
      ADC0.CTRLA = 0b00000000;                                     	             //ADC off, 10bit, normaler modus
      ADC0.CTRLB = 0b00000000;                                     	             //0 sampels accumulation
      ADC0.MUXPOS = 0b00000111;                                  	             // tempsense as input
      ADC0.CTRLA = 0b00000001;                                      	            //ADC on, 10bit, normaler modus
      ADC0.COMMAND = 0b00000001;                                  	            // start conversion!
      measurement = true;
tempCheck:
void checkTemp(){                                          // mesure temperature
  temp = ADC0.RES;
  temp -= sigrow_offset;
  temp *= sigrow_gain;         // Result might overflow 16 bit variable (10bit+8bit)
  temp += 0x80;                // Add 1/2 to get correct rounding on division below
  temp >>= 8;                  // Divide result to get Kelvin
  temp = (temp-273);             // temp to celsius
  batt = true;                                          // change next measurement value
batteryCheck:
void checkBattery(){                                          // mesure battery voltage
      battery = ((ADC0.RES-345)*3.65);                       // scale ADC values
      if(battery <= 0){                                      // set value to min if overflow
         battery = 0;
      if(battery >= 255){                                    // set value to max if overflow
         battery = 255;
      if(battery <= 1){                                     // ceck if undervoltage, than lockout
      dutyrLED = 0;                                          // setting dutyrLED for flashing
      UVlockout();                                           // go into UVL
      batt = false;                                          // change next measurement value
Vielleicht sieht jemand das Problem.
Batteriespannung funktioniert wunderbar, temp ist aber immer 325.
(ich hab den Code aufs wesentliche reduziert, da sind noch andere Funktionen drin, die machen aber alle keine Probleme, nur der Temp Sensor treibt mich seit mehreren Stunden in den Wahnsinn)
Danke
Farbe
Re: ATtiny1616 internen TEMP Sensor auslesen (Arduino)
Beitrag von sukram »
Moin. Ich habe jetzt nicht den überblick zu genau dieser Kombination (Tiny0 und Arduino) aber bei den Atmegas war es so, das nach jedem Umschalten (Referenz oder Eingang) die erste Messung verworfen werden muss, weil die Umschalter nicht synchronisiert sind.
xoexlepox
Beitrag von xoexlepox »
Ähh, seit wann wird bei einem Integer-Bitshift gerundet? Bei einer Division könnte das vielleicht sogar funktionieren, aber bei einem Shift werden m.E. nur Bits entfernt.
Farbe
Beitrag von Farbe »
sukram hat geschrieben: Sa 3. Apr 2021, 23:52 ... die erste Messung verworfen werden muss, ...
Deswegen schalte ih den ADC zwischendurch aus, schalte um, und schalte ihn wieder an.
Die Batterie Messung ergibt auch sinnvoller Ergebnisse beim ersten Messergebnis.
xoexlepox hat geschrieben: So 4. Apr 2021, 07:43 seit wann wird bei einem Integer-Bitshift gerundet?..
Gute frage, eigentlich ja nicht.
Wenn ich das richtig sehe macht das garkeine sinn:
temp ist 32bit (z.b.) = 01110000000000000000000000000001
dann kommt 0x80 hex dazu = 10000000
Temp = 01110000000000000000000010000001
dann wird geschiftet:
Temp = 000000000011100000000000000000000
Also wird es eh komplett raus geschoben??? 0,5 gibt es ja auch garnicht bei einem uint32_t? das stellt doch nur ganze Zahlen da?
Das Stückchen Code kommt aber direkt aus dem Attiny Datenblatt:
It is recommended to follow these steps in user code:
int8_t sigrow_offset = SIGROW.TEMPSENSE1; // Read signed value from signature row uint8_t sigrow_gain = SIGROW.TEMPSENSE0; // Read unsigned value from signature row uint16_t adc_reading = 0; // ADC conversion result with 1.1 V internal reference
uint32_t temp = adc_reading - sigrow_offset;
temp += 0x80; // Add 1/2 to get correct rounding on division below temp
uint16_t temperature_in_K = temp;
Ich hab mir da keine Gedanken drüber gemacht und das einfach eingefügt. Immerhin weiß ich eh nicht was der Temp sensor genau ausgibt. (und ich habe keine Ahnung von Programmierung)
xoexlepox
Tja, auch in einem Datenblatt kann Mist stehen ;)
Dann schau dir doch mal den A/D-Wert ohne irgendwelche Umrechnung an. Ändert der sich mit der Temperatur? Soweit wie ich es verstanden haben (und wie es in anderen Chips realisiert ist), wird allgemein ein (vom Hersteller einprogrammierter?) "Korrekturwert" von dem A/D-Wert abgezogen, und dann durch eine Konstante geteilt. Von dem Korrekturwert hängt es dann ab, ob du °C oder °K bei dieser Rechnung erhältst.
Farbe
Beitrag von Farbe »
Ich hab mal Dablas gewälzt, bei allein ATtinys ist dieser Code Schnipsel drin.
Scheinbar funktioniert das bei anderen auch.
Ich muss mal ein 2. Board bestücken und dort eine Serielle Schnittstelle benutzen. Dann kann ich mir wenigstens die Werte senden.
Aktuell habe ich nur eine LED zur Ausgabe...
Farbe
Beitrag von Farbe »
Ich hab heute mal ein 2. Board zusammengelötet und die Serielle Schnittstelle rausgeführt.
ADC sagt immer 1023.. mhm das ist MAX..
Referenz passt..
Dann fällt es mir wie schuppen von den Augen:
If(battery == true){
}else{
Ich hab den MUX nicht umgeschalten... scheinbar hab ich die Zeile kopiert und nur das Kommentar geändert. :oops:
mit:
ADC0.MUXPOS = 0b00011110;                                               // tempsense as input
gehts auf anhieb.
Was es mit "temp += 0x80; // Add 1/2 to get correct rounding on division below" auf sich hat weiß ich noch nicht. Ohne liefert es die selbe Temperatur raus.
manuel
Beitrag von manuel »
Das + 127 und dann /256 macht schon Sinn. Die Zahl nach der Multiplikation ist im q8 Format, 0x80 entspricht 0,5.
