My Peugeot Boxer has a built in radio (Cont?) with sat nav ,display etc.
There is no video inputs for cameras .Think they have to interafced to the can-bus.
These are very expensive to buy.
I have seen something on line,which I am trying to find out about.
It seems that an interface is placed inside the radio ( no mention of any connections ,just a mention of a ribbon cable).
This allows a camera to work with the display for reversing.
Does any body know anything about these systems ?
Thanks
Barry
FL VP2 ECE DAB NAV Radio
Re: FL VP2 ECE DAB NAV Radio
Thanks for your replies.
Problem seems to be there are lots of diiferent info diagrams ,pictures etc nearly all of them different ,even ISO.
Attached pic from my radio unit
Can-bus is on pins 2 & 12.
There are coonections to 29 & 39 which is MIC
There is also connections to 31 32 & 33 which is not mentioned.
I did find something on line which said it is possible to attach a camera to the AUX pins (5 6 15 & 16) if they have programmed (enabled)
Barry
Barry
Hi got to the bottom of this.
Took some solving.
Attached some info.
Barry
Took some solving.
Attached some info.
Barry
- Dateianhänge
- Reversing Camera Peugeot Boxer.odt
- (12.69 KiB) 19-mal heruntergeladen
Reversing Camera Peugoet Boxer Bailey Alliance
Fiat 250 FL Continental VP2 Radio
Look at the label after the words at the RH corner if it says NO CD ,NO RVC the unit is not programmed in the BCM (Alfasoft OBD)
My radio had a screened cable connected to pins 30 31 & 32 .I could not find where this cable went too ,so I tapped in too it
30 = Video
31= Return
33 = Screen and went to ground
With the ignition ON ,I could set up the radio to work with my camera.
Seems that the Sat Nav display is controlled by the Can Bus when you select reverse gear with the igntion on the camera display comes on.
Barry
30 = Video
31= Return
Barry
