TV-B-Gone -> Aufgeräumter Code
nero
Beitrag von nero »
Ich habe zur einfachen poprtierung der TV-B-Gone auf leistungsfähige Prozessoren (zB ARM Cortex) den Quellcode aufgeräumt und etwas lesbarer gemacht, so wie globale Variablen eliminiert.
Fall es jmd etwas ähnliches vorhat, stelle ich eine host-lauffähige Version des Ganzen mal hier rein.
Anhang in *.zip umbenennen und *.c und *.h finden.
Vorschau:
 * readable version of the TV-B-Gone code compression
 * hardware independent, runs on host systems
 * by Nero 2015
 * origins from
 * TV-B-Gone Firmware version 1.2
 * for use with ATtiny85v and v1.2 hardware
 * (c) Mitch Altman + Limor Fried 2009
 * Last edits, August 16 2009
 * and
 * With some code from:
 * Kevin Timmerman & Damien Good 7-Dec-07
 * Distributed under Creative Commons 2.5 -- Attib & Share Alike
 * for eu codes
#include <stdio.h>
#include "codes.h"
unsigned char uncompress_code(const unsigned char * c_field, unsigned char offs, unsigned char bit_compression)
  int i;
  unsigned char tmp = 0;
  unsigned char byte_num = offs * bit_compression / 8;
  unsigned char bit_num =  7 - ((offs * bit_compression) % 8);
  for (i = 0; i < bit_compression; i++) {
    if (bit_num < 0) {
      byte_num++;
      bit_num = 7;
    tmp |= ( ((c_field[byte_num] >> bit_num) & 1) << (bit_compression - 1 - i) );
    bit_num--;
  // return the selected bits in the LSB part of tmp
  return tmp;
void transmit_code(unsigned short on, unsigned short off, unsigned int f)
  return;
int main(void)
  unsigned short ontime, offtime;
  unsigned char i,k;
  unsigned int freq;
  unsigned char numpairs;
  unsigned char bitcompression;
  unsigned char ti;
  int sumofcodepais = 0;
  // for every POWER code in our collection
  for(i=0 ; i < num_EUcodes; i++) {
  // Read the carrier frequency from the code structure
  freq = EUpowerCodes[i]->timer_val;
  numpairs = EUpowerCodes[i]->numpairs;
  bitcompression = EUpowerCodes[i]->bitcompression;
  // Transmit all codeElements for this POWER code
  // (a codeElement is an onTime and an offTime)
  // transmitting onTime means pulsing the IR emitters at the carrier
  // frequency for the length of time specified in onTime
  // transmitting offTime means no output from the IR emitters for the
  // length of time specified in offTime
  sumofcodepais += numpairs;
  printf("    k     ti   on_t   off_t\n");
  // For EACH pair in this code....
  for (k=0; k < numpairs; k++) {
    ti = uncompress_code(EUpowerCodes[i]->codes, k, bitcompression);
    // read the onTime and offTime from the program memory
    ontime = EUpowerCodes[i]->times[2*ti];  // read word 1 - ontime
    offtime = EUpowerCodes[i]->times[2*ti + 1];  // read word 2 - offtime
    // transmit this codeElement (ontime and offtime)
    transmit_code(ontime, offtime, freq);
    printf("%5d  %5d  %5d  %5d\n", k, ti, ontime, offtime);
  printf("\ntotal number of code pairs: %d\n", sumofcodepais);
  return 0;
host.pdf
(15.17 KiB) 200-mal heruntergeladen
Zuletzt geändert von nero am Fr 15. Mai 2015, 21:16, insgesamt 1-mal geändert.
Atze
Re: TV-B-Gone -> Aufgeräumter Code
Beitrag von Atze »
Hallo Nero
Dankeschön für Deine Aufräumerei.
Wie ist denn die 'TV Ausschaltquote' heutzutage so?
Immerhin ist die Codeliste ja schon 6 Jahre alt.
bei meiner ist es durchwachsen.
billiggeräte der marke "ok" gingen nicht, und die marke LG war problematisch.
viele viele andere funktionierten.
