in der englische Wiki steht was von 35 KHz bei bis zu 2,5 KV
Although many variations exist, a plasma lamp is usually a clear glass sphere filled with a mixture of various gases (most commonly neon, sometimes with other noble gases such as argon, xenon and krypton) at nearly atmospheric pressure. They are driven by high-frequency alternating current energy at approximately 35 kHz, 2†“5 kV.[1] This energy flows from a high-frequency high-voltage transformer connected through an electronic oscillator circuit to a lower-voltage power supply, making a specialized power inverter. The high-frequency high-voltage power, or radio frequency energy, is transmitted into the gas within the globe through an electrode at its center. A much smaller hollow glass orb can also serve as an electrode when it is filled with metal wool or a conducting fluid that is in communication with the transformer output. In this case, the radio-frequency energy is admitted into the larger space by capacitive coupling right through the glass. Plasma filaments extend from the inner electrode to the outer glass insulator, giving the appearance of moving tendrils of colored light within the volume of the globe (see corona discharge and electric glow discharge).
Some globes have a control knob that varies the amount of power going to the center electrode. At the very lowest setting that will light or "strike" the globe, a single tendril is made. This single tendril's plasma channel engages enough space to transmit this lowest striking energy to the outside world through the glass of the globe. As the power is increased, this single channel's capacity is overwhelmed and a second channel forms, then a third, and so on. The tendrils each compete for a footprint on the inner orb as well. The energies flowing through these are all of the same polarity so they repel each other as like charges: a thin dark boundary surrounds each footprint on the inner electrode.
Placing a hand near the glass offers an attractive place for the energy to flow. The capacity of the large conducting body to accept radio frequency energy is greater than that of the surrounding air. The energy available to the filaments of plasma within the globe will preferentially flow toward the better acceptor. This flow also causes a single filament, from the inner ball to the point of contact, to become brighter and thinner.[1] The filament is brighter because there is more current flowing through it and into the 150 pF capacity, or capacitance, presented by an object, a conducting body, the size of a human. The filament is thinner because the magnetic fields around it, augmented by the now-higher current flowing through it, causes a magnetohydrodynamic effect called self-focusing: the plasma channel's own magnetic fields create a force acting to compress the size of the plasma channel itself.
Much of the movement of the filaments is due to heating of the gas around the filament. When gas along the filament is heated, it becomes more buoyant and rises, carrying the filament with it. If the filament is discharging into a fixed object (like a hand) on the side of the globe, it will begin to deform into a curved path between the central electrode and the object. When the distance between the electrode and the object becomes too great to maintain, the filament will break and a new filament will reform between the electrode and the hand. (see also Jacob's Ladder)
An electric current is produced within any conductive object near the orb. The glass acts as a dielectric in a capacitor formed between the ionized gas and the hand.
The globe is prepared by pumping out as much air as is practical. The globe is then back-filled with neon to a pressure similar to one atmosphere. If the radio-frequency power is turned on, if the globe is "struck" or "lit", now, the whole globe will glow a diffuse red. If a little argon is added, the filaments will form. If a very little xenon is added, the "flowers" will bloom at the ends of the filaments.[citation needed]
The neon available for purchase for a neon-sign shop often comes in glass flasks at the pressure of a partial vacuum. These cannot be used to fill a globe. Tanks of gas, each with its specific, proper, pressure regulator and fitting, are required: one for each of the gases involved.
Of the noble gasses, radon is radioactive, helium escapes through the glass relatively quickly, and krypton is quite expensive. Other gasses can be used. Molecular gasses may be dissociated by the plasma.
edit. könnte man da nicht mit einen elektronischen Hallogentrafo einen normalen Rückwärts speisen, und damit wieder einen normalen 12V Trafo Rückwerts bestromen?
